Activity › Forums › Apple Final Cut Pro Legacy › horrible looking footage – stroby
  • horrible looking footage – stroby
    Posted by Pete on March 27, 2007 at 2:47 am
    Hey guys, I’m doing, and editing favor for a friend of mine (FREE, yes FREE), and I’m editing or helping to edit a short film, the film was shot on a panasonic DVX-100A @ 24p so i went ahead and setup a capture preset @ 24fps (not sure if this was right to begin with), but I burned a DVD, and it looks like crap when i export it, and when i burned the DVD is even worst on the TV.
    Basically it looks like a field craziness, and the the motion on the scenes looks stroby, like is missing something.
    when I first started digitizing the footage, i remembered that the footage looked great but i was having problems with the audio, it was behind, so i figured it was some sort of frame rate issue, which when i changed the profile to the 24fps, it worked fine, but now it just looks terrible, and it doesn’t look that bad on screen.
    I just realized that maybe i should have digitized using the 59.xx setting is this correct?
    What’s the problem.
    Also does it matter that we used a different camera that does not play 24fps to digitize? I mean this was shot using the Panasonic, but we digitized from a regular DV camera used it as a deck, could this be the problem, what’s the ideal setting for this project?
    As always thans in advance, you guys are all great.
    Pete replied 19 years, 6 months ago 2 Members · 2 Replies
  • Adam Taylor
    March 27, 2007 at 10:54 am
    i can’t say for sure, as i haven’t used the set-up you described…However, i think you have answered your own problem. If it was shot 24p, then you must playback at 24p in order for it to be digitised at 24p.
    Imagine taking a 33rpm vinyl record (ah those were the days!), switching the record deck to 45rpm and recording a copy to tape. There is no way that the tape will ever sound right because what you fed in was wrong to start with – same principle.
    I’d redigitise with the correct camera attached then see if you still have the problem – good luck
    adam
  • Pete
    March 27, 2007 at 1:41 pm
    Thanks lightning, make sense. But i wasn’t sure if there was a workaround or not.
