Activity Forums Adobe Audition horizontal white lines in edit view
  • horizontal white lines in edit view
    Posted by Diederik on August 5, 2006 at 9:39 am
    In the edit view of Adobe Audition, 2 white horizontal lines are at +/- 30000 Hz or +-/90 % or +/- 0.9 norm. What is the meaning of this lines ?
    Thanks in advance,
    Diederik
    Blast1 replied 20 years ago 3 Members · 2 Replies
  • Willie Toth
    August 5, 2006 at 1:31 pm
    Waveform View (the default) displays a waveform as a series of positive and negative peaks. The x-axis (horizontal ruler) represents time, and the y-axis (vertical ruler) measures spikes, or increased amplitude, in a waveform.”
  • Blast1
    August 6, 2006 at 2:04 am
    [diederik] “What is the meaning of this lines ?”
    They are called Boundary Lines, they are controled in the Preferences Menu-> Display Tab, avaiable in the Edit Menu Dropdown, you can turn them on/off and adjust the level they appear at, -1DB is the default, you can set them to use as a guide for circumstants where you don’t want to exceed a certain level, like the safe areas for video, -1DB is a good point for clipping
