Activity Forums VEGAS Pro Horizontal Text Scroll is jerking in .wmv-file
  • Horizontal Text Scroll is jerking in .wmv-file
    Posted by Patrick Franz on December 15, 2008 at 8:51 pm
    Hi experts,
    I have a problem with my videos. If I add a horizontal text scroll to a video and render the video as a .wmv-file the text is jerking.
    Is there a possibility to avoid this text-jerking in Sony Movie Studio Platinum 8.0???
    Greetz,
    Patrick
    https://www.youtube.com/patrfran
    Terry Esslinger replied 17 years, 8 months ago 4 Members · 5 Replies
  • Jeremy Rasnic
    December 15, 2008 at 9:18 pm
    I am not familiar with the consumer version of Vegas so my recommendation may not even be valid.
    Have you tried changing the keyframes to linear and setting the smoothness to 0?
    Also, is it just the wmv file? If so, what are your render/encode spec’s? What is your project spec’s? If your fps is different then this may introduce some jerkiness. Also, you may want to change it from interlaced to progressive if it is not already.
    j razz
  • Patrick Franz
    December 15, 2008 at 9:49 pm
    Hi razz,
    thanks for the quick answer…
    I tried to render just a text scroll, without any original video. The problem still persists and exists with most of the codecs.
    I used the progressive mode and the keyframes are linear. Its a video of 1440×1080 resolution, but the same with lower resolution.
    Where can I change the smoothness? Is this the video smoothness (quality)?
    For me it seems, that the text ist rendered jerky already. This means that 3 or 4 frames could be the same, then the text moves and again 3 or 4 frames and so on…
    Could be that i’m wrong, but at the moment in my oppinion this could be real…
    Greets and Thanx,
    Patrick
  • Douglas Spotted eagle
    December 15, 2008 at 9:52 pm
    Hold up….how many keyframes are thre in the scroll?
    If there are more than two, it’s entirely likely that it’s the keys themselves that are generating the jerkiness.
    Can you send a link to a sample?
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Patrick Franz
    December 15, 2008 at 10:03 pm
    there are only two keyframes.
    A sample is there:
    https://www.youtube.com/watch?v=mjpzm0ScoRs
    and
    https://www.youtube.com/watch?v=yaTPQm9PDXA
    always in the las few seconds.
    I have many more examples…
    Greets,
    Patrick
    (ps: i go to bed now (Switzerland 11pm))
  • Terry Esslinger
    December 15, 2008 at 10:22 pm
    Your beginning vertical scrolls are also slightly jerky, just not as noticeable as the horizontal scrolls. I have repeadedly had problems with the vertical scroller but have been able to get smooth horizontal scrolls. What are the specs on the computer and hard drive that you are using?
    I recently did some serious scrolling of photos across the screen and they were not smooth, no matter what I did and what I had my preview set at. However when I rendered it out and played it on a DVD player it was smooth as silk? Who knows?
