Activity Forums Apple Final Cut Pro Legacy Horizontal lines issue need professional guide
  • Horizontal lines issue need professional guide
    Posted by Shahrukh Sami on March 21, 2014 at 9:30 am
    I am editing a documentary that is recorded on Sony PMW-EX3 HD (1920*1080).
    I convert footage to apple ProRess22 (25 fps 1920*1080).
    After editing and exporting the final project i notice horizontal lines appear specially in moving and pan shorts. These lines also show in recorded files before converting. While playing it on Sony 42″ LED it lags on screen and show horizontal line as well.
    I wana know is this
    1-Problem in camera recording formate ?
    2-Footage Conversion problem ?
    3-Exporting problem ?
    sample image…..
    Shane Ross replied 12 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Mark Suszko
    March 21, 2014 at 3:14 pm
    Check to see if your field order is reversed, but this may be a camera artifact, or it happens during the conversion. What is the native recording format? AVCHD?
  • Shane Ross
    March 21, 2014 at 4:57 pm
    How are you sending the signal to the LED screen? That’s interlacing…perfectly normal in many instances. Works when broadcast, played from tape, or on DVD or BluRay. But if played from a computer…if the display is connected directly to a computer…then it won’t play back properly. Computers don’t do interlacing.
    Shane
    Little Frog Post
  • Mark Suszko
    March 21, 2014 at 5:26 pm
    I thought it was interlace, but thought maybe too it could be a combing artifact.
  • Shahrukh Sami
    March 22, 2014 at 4:36 pm
    I work in upper field. Yes it was recorded AVCHD.MP4 format. I can saw these lines even camera recorded source footage before editing.
  • Shahrukh Sami
    March 22, 2014 at 4:37 pm
    I convert it to .mp4 (1920*1080) with H.246 and use USB to preview it on LED.
  • Shahrukh Sami
    March 22, 2014 at 4:39 pm
    I also access that it is due to interlace of footage but why hollywood movies trailer don’t show such behaviour.
  • Shane Ross
    March 22, 2014 at 7:16 pm
    Hollywood movies aren’t shot interlaced, nor are they shot with AVCHD cameras. And you are viewing a computer signal on that TV. Computers don’t display interlacing properly.
    Shane
    Little Frog Post
