Activity › Forums › Avid Media Composer › Horizontal Lines in Full Screen Playback
Posted by Trevor Ambrose on March 28, 2014 at 9:18 pmHi all,
I am editing with only 2 screens. (my left Dell monitor has the bins, the composer and the timeline — my right Dell monitor is in Full Screen Playback)
There are horizontal lines when playing back in full screen that create a ragged image.
I can see in the small composer window that the image is fine.
I am newly transforming my edit situation from FCP to Avid and I’m not really understanding what’s going on. In FCP Full screen is fine.
Any clues out there?
Trevor Ambrose
Trevor Ambrose
Oliver Peters replied 12 years, 5 months ago 3 Members · 5 Replies -
Shane Ross
March 29, 2014 at 12:44 am[Trevor Ambrose] ”
There are horizontal lines when playing back in full screen that create a ragged image.”That’s interlacing. Computer displays connected via computer connections cannot show interlacing properly.
[Trevor Ambrose] “I can see in the small composer window that the image is fine.”
The Preview and Program monitor drop one field when they play back, so you don’t see this.
[Trevor Ambrose] “I am newly transforming my edit situation from FCP to Avid and I’m not really understanding what’s going on. In FCP Full screen is fine.”
YOu need an IO device outputting to an HDTV to see this properly. YOu can get a Decklink Mini Monitor (PCIe for tower or Thunderbolt connected) for $150.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Oliver Peters
March 29, 2014 at 6:53 pmIt could be interlacing as Shane mentioned, but it could also be the horizontal tearing that has plagued Avid for years. That’s a result of refresh rates and computer screens. Launch Avid MC and type the “moncon off” command in the console. See if that fixes it. If so, you will need to re-enter this every time you launch MC, since it resets to the default when the program starts. I only suggest this because you mentioned FCP was fine. If it were interlacing, then I would think you’d see that same issue (with the same media) in FCP.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Trevor Ambrose
March 30, 2014 at 4:27 amHey Shane,
Thanks so much for your detailed response. I no longer have the problem. Like Oliver said, if I go to console and type “moncon off” it stops tearing.
That being said, it’s a little irritating. I like to “hide video” to the small composer windows and if I do that and put moncon off then I can’t have a “full screen playback”. I could go back and forth between modes but it’s a little cumbersome.
I’m interested in your decklink suggestion. I have a decklink intensity card with a couple of HDMI ports so maybe if I hook up another monitor to HMDI it will allow me to be in full screen with no tearing.
Anyway, it’s got me thinking. Thank man!
Trevor
Trevor Ambrose
editor
https://www.imdb.com/name/nm0024430/ -
Trevor Ambrose
March 30, 2014 at 4:35 amThanks Oliver! That solved everything.
My only problem now is, I like to “hide video” to the small composer windows and if I do that and put moncon off then I can’t have a “full screen playback”. I could go back and forth between modes but it’s a little cumbersome.
I’ll figure it out.
I see you are from Florida. My parents live in Aventura 6 months a year and I visit with my wife every year. What an awesomely beautiful state!!!
Have a good one.
Trevor
Trevor Ambrose
editor
Oliver Peters
March 30, 2014 at 12:44 pmGlad it worked for you. Unfortunately it’s a hack, but at least it’s an answer until Avid eventually fixes this issue.
Glad your parents are enjoying the state.
Cheers,
OliverOliver Peters Post Production Services, LLC
Orlando, FL
