Activity Forums Adobe After Effects Horizontal lines across moving subjects?
  • Horizontal lines across moving subjects?
    Posted by Ash Davis on April 28, 2010 at 1:07 pm
    Hi Guys
    I have some footage that I’ve captured on to AE, all of which I used a tripod to shoot. The stills and backgrounds are fine but anything moving has horizontal lines around the edges, is there anyway I can elimate the lines?
    Todd Kopriva replied 16 years, 4 months ago 3 Members · 2 Replies
  • Dave Johnson
    April 28, 2010 at 2:03 pm
    Sounds like you may be referring to the jagged edges that are normal with interlaced footage … check AE’s interpret footage settings to make sure the footage has been interpreted correctly (i.e., interlaced or non-interlaced, etc.). You can de-interlace the fooatge if needed depending on what you want your output to be, but if it is supposed to be interlaced, it will look fine on a TV so de-interlacing may not be necessary or appropriate.
  • Todd Kopriva
    April 28, 2010 at 6:40 pm
    To add to what Dave said:
    You should be separating fields when you import interlaced footage.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
