Horizontal bars sliding transition effects
Trying to re create a transition effect used in the Adidas ad below.
https://vimeo.com/134966392
The effect happens at 00:02 and also at 00:55. Face transitioning.
I tried making this effect as a black and white transition in a pre comp and then applying it back to the face with horizontal scaling effects. Not getting it right, though.
ShyamSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
