Horizontal bars at top+bottom clipping image animation
Derek Moran replied 11 months ago 3 Members · 13 Replies
Derek Moran
October 3, 2025 at 9:14 amHi again
I posted in a hurry this morning, and have now revised my solution/s.There are 2x different VP20 .veg project files for you to look at:
1. Version #1 is the exact same method you created, but with fixed Key-Frames that don’t shift in aspect ratio, as they spin upwards.
2. Version #2 is my simplified method – the same one I explained with screen shots.Personally, I think your method #1 is more elegant and looks nicer!
In both project files, I have included a basic image, so you don’t have to muck around swapping files out. -
Neil Pollick
October 4, 2025 at 3:22 pmThanks for the input and the Vegas 20 project files
It’s sorted now.I went with the first one … the slight difference in mine is that the images are a bit smaller. I made it that way to leave space on the right side of the frame for the titles.
I was surprised by the arc that the photos moved in with just a key frame at the start and at the end but it was what I was going to try and do – yet it just happened like that!
I will post the final titles as an mp4 if you like? (not ready yet, I got side tracked)
Derek Moran
October 5, 2025 at 12:22 amExcellent! Thanks for posting back 😀
There are some very cool tricks you can do, when adding key-frames!
