Activity Forums Adobe After Effects Hoping to reduce jittery text rendered from AE
  • Hoping to reduce jittery text rendered from AE
    Posted by Mike Tosetto on September 20, 2013 at 12:35 am
    Hey guys
    I’m working on quite a simple video with lots of vertical lines moving horizontally across the screen revealing text.
    I’m finding that I’m getting quite a bit of jitter/flicker, especially on the text when I render the footage.
    I’m rendering to a lossless codec – Apple ProRes 422 HQ
    The frame rate is 25 fps.
    I don’t want to add any motion blur as it’s not in line with the brand but I’d like the lines and text to be as smooth as possible.
    I did notice that when I increase the frame rate, the flicker seems to reduce, but am I able to upload a video with a frame rate of 100fps to Vimeo?
    Here’s a link to an 8MB sample of the video:
    https://www.dropbox.com/s/0phyw3tnnjqtr4i/jitterExampleLo.zip
    Any thoughts or suggestions would be much appreciated.
    Cheers
    Mike
    miketosetto dot com
    Nathan Howe replied 13 years ago 4 Members · 3 Replies
  • Roland R. kahlenberg
    September 20, 2013 at 2:11 am
    It’s too troublesome to take a look at your video – I suggest uploading it to the COW and then provide the link in your posts.
    To remove the jitters, try lowering the opacity and if that doesn’t work, look at trying different speeds for your movement.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Todd Kopriva
    September 21, 2013 at 4:54 pm
    See this page for tips on avoiding judder:
    https://kb2.adobe.com/community/publishing/908/cpsid_90843.html
    After Effects team blog
  • Nathan Howe
    September 23, 2013 at 7:27 pm
    Rather than adapting to multiples of frame rate, as animated motion is sometimes an arbitrary numerical value, I’ll almost always use some type of motion blur, but it depends on the project. I have done it both ways though…
