Activity Forums Maxon Cinema 4D Hopefully simple shader effector question
  • Hopefully simple shader effector question
    Posted by Espen Jakobsen on August 4, 2010 at 1:14 pm
    I’m simply trying to rotate som letters with the shader effector. Usually I use the mograph text object, and it’s easy to link the shader effector into the text object.
    But in this case I have a bunch of separate letters (paths from illustrator, extruded and turned into objects), they’re all parented under a null object. Is there a way I can affect these letters with the shader effector when they’re not inside an object I can easily link them to a shader effector?
    Espen Jakobsen
    Multimedia Designer
    https://massiverhino.no/
    https://www.espenja.com/
    Espen Jakobsen replied 16 years, 1 month ago 2 Members · 2 Replies
