Activity Forums DaVinci Resolve Hooks LUTS not showing up in Davinci 11
  • Hooks LUTS not showing up in Davinci 11
    Posted by Liz Parham on September 9, 2014 at 4:39 pm
    Installed Hooks LUTs, but when I right click “3D lut” I do not see them? I’ve already checked to see if they’re in the correct folder in my mac library. Maybe they’re not compatible with 11?
    Liz Parham replied 11 years, 7 months ago 3 Members · 3 Replies
  • Tom Bakkejord
    September 23, 2014 at 9:34 am
  • Ross Connard
    December 30, 2014 at 10:25 am
    I had this problem as well.
    The solution is, fortunately, easy.
    The LUTS are not showing up because they have the incorrect permissions. If you’re using a Mac, use finder to navigate to the LUTS folder
    /Library/Application Support/Blackmagic Design/DaVinci Resolve/LUT
    In the LUT folder, get info on ‘Hook LUTs’ and at the bottom of that window click ‘Sharing & Permissions’ Click on the lock at the bottom right of the window, type your password. Then change all permissions to ‘Read & Write’. Restart Resolve and you’re good to go.
    You can also do this with Terminal, and I’ve got no idea how to reset permissions on Windows.
    Happy lutting and thank you, Mr. Hook.
  • Liz Parham
    January 22, 2015 at 8:06 pm
    great, thanks!
