Activity Forums Apple Final Cut Pro Legacy Hooking up an external plasma
  • Hooking up an external plasma
    Posted by Jim Bell on September 14, 2010 at 2:21 am
    I am shooting SD on dvx100b and editing in FCP3. Someone in the basics forum told me I could go firewire to camera and camera outputs to the plasma as a cheapo alternative to a dv bridge card.
    So I’ve hooked it up fw to cam, SD cable to plasma and NOW my question is what should the FCP and or cam settings settings be to get the timeline playback pumping to the plasma as well as the monitors?
    Hope I’m not barking up the wrong tree here…
    Suggestions, thoughts, abuse, whatever appreciated.
    jb
    10.6.1, MacPro Quad 6GB RAM, Macbook Pro 17″ w/G-Tech 2 TB GRaid with Sonnet Tempo eSATA via express card, FCS3, TC Electronic Impact Twin FW audio interface, 2 DVX100Bs
    Shane Ross replied 16 years ago 4 Members · 3 Replies
  • Steve Eisen
    September 14, 2010 at 2:30 am
    Easy setup DV/NTSC
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Bret Williams
    September 14, 2010 at 2:46 am
    And you have to make sure the cam or deck is passing the signal through. Make sure EE mode is on.
  • Shane Ross
    September 14, 2010 at 2:52 am
    [Jim Bell] “Someone in the basics forum told me I could go firewire to camera”
    That would be me. And they steered you right.
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    Shane
