Activity Forums Panasonic Cameras hooking a standard Def monitor to my HPX 170- no signal
  • hooking a standard Def monitor to my HPX 170- no signal
    Posted by Danielle Lussier on July 9, 2010 at 6:42 pm
    I have tried to hook my hpx 170 composite AV cord / and SDI cord with 1/8 ” mini plugin to an external Standard Definition LCD Monitor and I do not get a signal. Can some one help me understand why? I know there must be a compatibility issue but I am unsure as to where the issue is?
    Danielle Lussier replied 16 years, 2 months ago 4 Members · 4 Replies
  • Jim Carswell
    July 9, 2010 at 6:48 pm
    You are sending an HD signal to a non HD monitor. The monitor is not capable of down converting the signal.
    Jim
    Jim Carswell
    Spyhop Productions, Inc.
    Savannah, GA
    http://www.spyhopproductions.com
  • Sohrab Sandhu
    July 9, 2010 at 7:49 pm
    Go to the menu options, select the 480i option in the AV playback option.
    You should be able to get SD signal on your monitor now.
    2.66 GHz 8-core, ATI Radeon HD 4870,
    FCS 3, AJA Kona Lhi
    “The creative person wants to be a know-it-all. He wants to know about all kinds of things: ancient history, nineteenth-century mathematics, current manufacturing techniques, flower arranging, and hog futures. Because he never knows when these ideas might come together to form a new idea. It may happen six minutes later or six months, or six years down the road. But he has faith that it will happen.” — Carl Ally
  • Steve Eisen
    July 10, 2010 at 3:19 am
    Your only option is Composite (Yellow, Red and White) or Component (breakout cable with Green, Red and Blue) if your LCD has those inputs.
    SDI will ONLY work with a monitor with an SDI input.
    I’m not understanding your SDI with 1/8″ plug. This definitely is NOT and SDI cable. SDI is BNC to BNC.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Danielle Lussier
    July 12, 2010 at 2:49 pm
    Thanks for your input- I realize now what I was doing- and I finally found the AV connection above the xlr hookup. Silly me. Thank you for your responses – very helpful!
