Activity › Forums › Adobe Premiere Pro › Home screen blank
Home screen blank
Posted by Pavel Kuklin on January 25, 2024 at 2:30 amMads Nybo jørgensen replied 2 years, 7 months ago 3 Members · 7 Replies -
Mads Nybo jørgensen
January 25, 2024 at 8:28 amHey Pavel,
Sometimes it does that.
Have you tried to open or create a new project using the top menu?
Mads -
Pavel Kuklin
January 25, 2024 at 9:21 amI close this screen as it is useless like this.
Everything seems fine otherwise. Trying to figure out why this is happening.
Mads Nybo jørgensen
January 25, 2024 at 9:52 amAdobe works in mysterious ways, which can lead to the software not loading and/or crashing.
If it persists and if it stops you working, I’ll suggest you try following until you get that screen:
1) Trash the preferences and empty the cache.
2) Make sure that you have the latest version of Creative Cloud Desktop and Bridge installed?
Same goes for cheking that your Mac is on the latest version.3) Uninstall Adobe, and re-sinstall…
Hope that this helps?
Mads -
Tom Morton
January 26, 2024 at 7:42 amOr… uninstall Adobe and install Davinci Resolve instead!
These errors are sadly part of the Premiere Pro workflow – Adobe always like Premiere Pro to run into a few errors occasionally, this is part of a special user selection process. If you’re good enough to solve the errors and keep working, then you’ve passed the test and you can keep using Premiere Pro.
However, if you keep passing the tests, then Premiere Pro is programmed to make the tests harder and harder to see how much you can take. Unfortunately this has backfired on Adobe more recently as video editors have been finding out that this isn’t standard practise with other software developers and NLE’s like Davinci Resolve and Final Cut Pro try and avoid this workflow where possible, and this actually makes their programs more enjoyable to use.
PS: Warning, my writing may be infused with sarcasm and/or cynicism.
Pavel Kuklin
January 26, 2024 at 9:52 pmI would love to work in Davinci, I have it. But the mac I have does not let it work smoothly.
At least Adobe works and more stable … with Davinci is somewhat annoying as it hangs and takes its time etc…
Pavel Kuklin
January 26, 2024 at 9:54 pmok thanks.
Don’t get why it is like this. It was working fine untill one of the apple updates… and that is it.
That is only with the first screen. The program itself works fine… What is the bridge?
Mads Nybo jørgensen
January 27, 2024 at 1:02 pm
