Activity Forums Apple Final Cut Pro Legacy holographic image
  • holographic image
    Posted by Gnwanya on December 5, 2006 at 1:19 am
    I guys
    Im hoping you can help me here. I have hdv footage, captured using a greenscreen. I have created a background image, and i want to apply a tv lines effects to my greenscreen footage and make the footage semi transparent. My problem is applying the tv line effect to the greenscreen footage, and nothing else. I need to mask of the lines from appearing on my background footage. I have created the tv lines in a photoshop document as a psd.
    I am also considering using AE7 which i know i can easily achieve the effect there. But i have a alot of footage to edit, and i dont know the best way to transfer my editited footage back and forth across platforms without a plugin such as automatic duck.
    Any advice would be appreciated.
    Gus
    Gnwanya replied 19 years, 9 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    December 5, 2006 at 2:19 pm
    You can export a self contained QT movie from AE matching your sequence settings in FCP, import that and edit in right in…
    Jerry
  • Gnwanya
    December 7, 2006 at 12:12 pm
    Thanks for your advice. I’ll look into it.
    Much appreciated
    Gus
