Activity Forums Apple Final Cut Pro Legacy Hollow Voice Over
  • Hollow Voice Over
    Posted by Sulaman Hameed on January 22, 2009 at 9:11 am
    Hello,
    I edit an interveiw. The interviewing person audio was hollow recording. I think mic not working well and camera mic recording this VO …
    anyone suggest me any filter to fix this audio to make good.
    Mac pro, final cut pro 5,
    Sulaman Hameed
    Non linear Editor
    Dawnnews.tv
    Karachi, Pakistan
    Tom Brooks replied 17 years, 7 months ago 3 Members · 3 Replies
  • Tom Brooks
    January 22, 2009 at 12:43 pm
    Equalization is usually the key. The hollowness is caused by certain frequencies of sound being emphasized by the acoustic properties of the room. Usually, reflections in the room will increase certain frequencies and decrease others. The first thing is find the frequency that is overly loud and reduce that. Then, attempt to judge what is missing from the audio. Finally, a little noise reduction can help. I would work in Soundtrack Pro.
    Final Cut Pro 6.0.5, Mac OS-X 10.5.5, Quicktime 7.5.5, Adobe Prod Prem CS4, G5 Quad 2.5, Kona-LHe V6, 8.5GB RAM, Nvidia GeForce 7800-GT 256MB, G-RAID 2x1TB FW800, 6TB RAID-5 (Enhance E8-ML, Highpoint 2322), Panasonic HVX-200P P2. Also MBP 17″ Core 2 Duo 2.5, 4GB, GeForce 8600M GT 512MB.
  • Arnie Schlissel
    January 22, 2009 at 8:45 pm
    There really is no way to remove reverberation from audio. At best, you might be able to reduce it very slightly, but with a reduction in your sound quality. The best thing to do is to bring this to an audio professional, a specialist. They probably won’t be able to really improve it very much, either.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Tom Brooks
    January 23, 2009 at 3:38 am
    All I’m sayin’ is that when it’s all you got, some EQ can help. It’s not the reverb you’re getting rid of at all, it’s just the unpleasant effect of room resonance. If a room rings like a bell at 300Hz, you can sometimes make a big difference by using a parametric eq at 300Hz to reduce the effect of that resonance on your recording.
