Activity › Forums › Apple Final Cut Pro Legacy › HOLDING SYNCH DURING PLAYBACK – DVCPRO HD/LONG TIMELINES
  • HOLDING SYNCH DURING PLAYBACK – DVCPRO HD/LONG TIMELINES
    Posted by Jim Blokland on March 23, 2007 at 2:25 am
    Hello:
    I’ve had some playback synch issues playing back shows with my setup. I have a 2.7 Dual G5, Kona 2 card, Dual Firmtek Serial ATA RAID arrays with WD CAVIAR II RAID drives. I noticed this problem on two recent shows — one was a 40-minute film shot in 24P on mini-DV, the other was a short film shot on the HVX2– at DVC PRO HD resolution.
    When I’m cutting, I don’t notice any synch issues, because I’m only looking at short bits. When I played back the shows for the client, the audio synch would slowly drift over the length of the show. If you stopped playback and immediately started it again, it would return to perfect synch and then drift out again.
    I have a feeling there’s a setting somewhere that is incorrect…I find it hard to believe that my drives wouldn’t be fast enough for this material.
    Any real-world advice appreciated. Oh yeah, I’m running the latest/greatest in terms of system and FCP software.
    Thanks in advance.
    Best, JIM.
    OSX.4.3
    Dual 2.7 G5
    3.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
    Seritek 1.2 TB RAID
    AVID XPRESS PRO/MOJO
    Jim Blokland replied 19 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
  • Randy Johnson
    March 23, 2007 at 9:03 am
    I have the same issue…but not with DV material only HDV and 24p…I wish I could help you.
    I am using fcp 5
    Kona 2
    K-box
    5.5gb ram
    dual raid scsi hard drives.
  • Shane Ross
    March 23, 2007 at 2:45 pm
    Well, for working with long projects, I tend to break them up into smaller sequences. Since I edit TV I have the benefit of being able to work with Acts, the sections between the commercials. These are never longer than 20 min. And people who cut film tend to break up their sequences by reel…again, 20 min. So maybe you can break your sequences up into sections.
    When it comes time to output, I export the entire timeline as a self contained Quicktime Movie, reimport it into FCP, then output. No sync issues.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    March 23, 2007 at 5:43 pm
    GO to your preferences and make sure that report dropped frames is on. Perhaps you are dropping frames and don’t even know it. FCP will try to keep up, but when it does it will often lose sync.
    If that doesn’t work, mix down your audio by selecting all (command-a) then hitting option-apple-r. This will help with playback.
    Make sure all of your effects are rendered, even the ones marked ‘full’. Render it all.
    Jeremy
  • Jim Blokland
    March 23, 2007 at 10:34 pm
    Hi folks:
    Thanks for the responses. I wouldn’t think that FCP with a RAID array should be dropping frames on a mini-dv drama with very few effects — and this is on a 40-minute timeline with only about 8 tracks of audio. I certainly have no drop frame issues or synch issues with the same rig but running AVID XPRESS PRO HD.
    I wonder if it could be something else…
    This is a major consideration for me, as I’m about to cut a feature film and can’t afford to output to Quicktimes just to be able to screen for the clients…
    Any other tips out there?
    Thanks in advance.
    Best, JIM.
    OSX.4.3
    Dual 2.7 G5
    3.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
    Seritek 1.2 TB RAID
  • Jeff Coleman
    March 24, 2007 at 12:49 am
    Just recently you noticed sync issues? What were the last known combination of software versions that didn’t display this problem with long timelines?
    What version of QT are you running?
    Love,
    Jeff
    Final Cut Studio 5.1, G5 2GHz Dual Processr, 2.5Gb RAM, AJA IO
  • Jim Blokland
    March 24, 2007 at 1:00 am
    Hey Jeff:
    I had the synch issues on the last 2 projects, completed in summer & fall 2006. At the time I was running OS 10.4.6 (if memory serves…) and whatever the concurrent QT version was. I can’t really comment as to when I didn’t have the issue, as probably most other projects before these were reasonably short and I just may have not noticed. (I’ve been meaning to post this anomaly for awhile, but I’ve been using AXP for the last 5 months or so on some other gigs.)
    Perhaps I’ll try a playout this weekend of one of the old projects with the software I’ve got now (10.4.9, Quicktime 7.1.3) and see if I still have the issue.
    Best, JIM.
    OSX.4.3
    Dual 2.7 G5
    3.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
    Seritek 1.2 TB RAID
  • Jtv Preditor
    March 28, 2007 at 5:39 pm
    Be sure to check the audio bit rate of the original camera recording. Some mini-DV cameras have a 32 khz, 12 bit setting as a default instead of the 48 khz standard. If captured and dropped into a 48 khz timeline, the long clips will drift out of sync.
    JTV Preditor
  • Jim Blokland
    June 15, 2007 at 1:58 am
    Hi folks:
    I know this goes a bit back, but I think I have tracked down the problem…one thing I neglected to mention was that I was running an M-AUDIO Firewire 410 box as an audio interface — and I think that was the culprit.
    Somehow, there seems to be a synch drift via firewire on this box, that gets cleared up as soon as you stop and start the sequence again. I listened to the same project that was going out of synch — but this time via the Mac’s audio outs — no loss of synch.
    Guess I’ll be hooking up my K-Box again and going back to 2-channel RCA outs for monitoring.
    Best, JIM
    OSX.4.3
    Dual 2.7 G5
    3.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
    Seritek 1.2 TB RAID
