Activity Forums Adobe Premiere Pro Holding “stable” wb setting in footage form multiple devices
  • Holding “stable” wb setting in footage form multiple devices
    Posted by Andrew Rabka on July 26, 2018 at 3:38 pm
    Could anyone give me a tip where look for tutorials/books/materials ect. which allow correct, badly recorded footage?
    I have used canon 5d II and lumix g80. There are a lot of scenes which have mismatched white balance setting. Every tutorial which I have seen is about correcting something what doesn’t need correction at all in my opinion.
    The point is, I have cut 40 minutes movie and now I want correct it one clip after another. Effect which interest me is getting “stable” colours in whole material. Now
    when I am trying to do it, the effects is not constant. For example in first 2 minutes everything is ok – human eye can’t see differences between following scenes, but when I compare 2 an 20 minute of movie there is a huge mismatch. How to prevent it?
    Thanks in advance
    Chris Wright replied 8 years, 1 month ago 2 Members · 1 Reply
  • Chris Wright
    July 26, 2018 at 4:33 pm
    is it changing every 2 seconds or every 5 minutes? something slower you could keyframe white balance and fade between the clips so its gradual or cut adjustment layer and use dissolve.
    something changing every 2 seconds would require AE unless there is an auto color stabilizer for premiere.
