Activity Forums Adobe After Effects Expressions hold last frame expression
  • hold last frame expression
    Posted by Sam Pauwels on March 1, 2022 at 10:23 am
    I’m building an After Effects template where I would like to have an expression that finds the last frame of a comp or footage that will change every day.
    I’ve tried with a timeRemap expression outPoint – 0.04 but for some reason that doesn’t work.
    Any advice anyone?
    Filip Vandueren replied 4 years, 6 months ago 2 Members · 5 Replies
  • Filip Vandueren
    March 1, 2022 at 6:19 pm
    Not sure, but maybe source.length – source.frameDuration ?
  • Sam Pauwels
    March 1, 2022 at 11:06 pm
    hmm, that does not work, at least not as a timeRemap expression. I guess maybe because length is a distance property, not a time property?
  • Filip Vandueren
    March 2, 2022 at 8:05 am
    D’oh,
    I meant:
    source.duration-source.frameDuration;
    alhough just source.duration; will probably work too because time remap should take care of showing the last frame even if the number is too high.
    So in theory even this works too:
    Number.MAX_VALUE;
  • Sam Pauwels
    March 2, 2022 at 8:25 am
    Hey Filip,
    Thank you so much! that first line works perfect!
    source.duration gives the full duration of the layer. In TimeRemap that means it returns a blank frame. Same with number.MAX_VALUE.
    Also very nice to see Belgian people here, I’m from Borgerhout. As a matter of fact, I went to school with your girlfriend/wife 😀
  • Filip Vandueren
    March 2, 2022 at 8:36 am
    Hi Sam, it’ll give a blank frame for a precomp, but not for footage.
    Groetjes uit Diest 🙂
    Filip
