Activity Forums Adobe After Effects Expressions Hold Keys from Expressions
  • Hold Keys from Expressions
    Posted by Matthew Tully on October 30, 2007 at 8:35 pm
    Right now I have a comp with 4 3D layers. I have attached them to a 3D null and added a wiggle to the Orientation of the Null. Right now the expression is interpolating the movement between the keyframes (every 1/2 a second)…So what I want to know is can the keyframes (the ones that exist inside the expression) be hold keyframes? Does this make sense? Please help if you can.
    Matthew Tully replied 18 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 31, 2007 at 2:04 pm
    Not sure what you mean by keyframes that exist inside an expression, but you can use posterizeTime(n) (where n is the frames per second that you want the expression to update). You’d just add it to the front of your expression.
    Dan
  • Matthew Tully
    October 31, 2007 at 7:40 pm
    This is just what i was looking for. I was trying to describe the virtual keyframes created, the data points generated by expressions. Thanks Mr. Ebberts.
