Activity Forums Adobe Premiere Pro Hold Frame — suddenly stops working??
  • Hold Frame — suddenly stops working??
    Posted by Jeff Nelson on October 26, 2005 at 6:05 pm
    Editing something here this morning, took a shot where I want to hold on the first frame. Did it on one shot, but now won’t do on another. Any idea why? I’ve rebooted, in case something was messed up.
    I go to Frame Hold, Hold on In Point, click Okay, and nothing happens. I’m on the edit line where I should be, normally it would make a brown line appear above the shot meaning it needs to be rendered. But nada. When I check, it shows it *is* checked for the shot to hold on the first frame, but it won’t do it.
    Any suggestions?
    Jeff Nelson replied 20 years, 11 months ago 2 Members · 2 Replies
  • Tim Kolb
    October 27, 2005 at 3:15 pm
    Are you using a board like the DV Storm in your system?
    TimK,
    Kolb Syverson Communications,
    Creative Cow Host,
    2004-2005 NAB Post Production Conference
    Premiere Pro Technical Chair,
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Jeff Nelson
    October 28, 2005 at 11:27 pm
    You are correct. And I found that if I add any effect to the clip, the hold frame works. Temperamental, eh?
