Activity Forums Apple Final Cut Pro Legacy Hmmm..Can I…Workflow Question
  • Hmmm..Can I…Workflow Question
    Posted by Daniel5000 on June 2, 2008 at 8:09 pm
    Hello All
    Apologies for what might be a very obvious question.
    I would like to edit in a 1280 x 720p sequence as I have some poorly shot interviews, which could be greatly improved with a bit of repositioning. Source material is XDCAM HD 108050i 35Mb/s VBR.
    Possible delivery to DVD but also computer and web playback, but as of yet undetermined.
    Any suggestion for sequence setup? Is it a good idea?
    Was experimenting with dropping everything into a ProRez or DVC Pro HD sequence.
    All of which, as many of you know, have pro and cons regarding quality etc etc. Also considering that the source material is interlaced..then going to progressive sequence.
    Hmm..just looking for any suggestions.
    Many Thanks
    Daniel
    Basic System Information
    FCP 6.0.2
    BlackMagic Multibridge Extreme running decklink 6.6.1
    QuckTime 7.3.1
    Daniel5000 replied 18 years, 3 months ago 3 Members · 3 Replies
  • Tom Wolsky
    June 2, 2008 at 8:16 pm
    Your media is quite a bit larger than 1280×720 so you should have enough extra space for reframing.
    There is a function in FCP preferences in the current version about what to do with images that don’t match sequence size. You can set it to automatically rescale or do nothing. You might want to set it to the latter if you’re going to reframe a lot of them.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Jeremy Garchow
    June 2, 2008 at 9:12 pm
    What Tom says, and then you will probably have to get a nice deinterlace going on your material when you are done.
    Jeremy
  • Daniel5000
    June 6, 2008 at 1:38 pm
    Gentlemen…apologies for not getting back to your posts earlier.
    Many Thanks
    Daniel
