Activity › Forums › JVC Cameras › HM700 w/Fuji17X need filters
  • HM700 w/Fuji17X need filters
    Posted by Doug Calhoun on February 19, 2010 at 9:47 pm
    Hi all,
    I’m looking for a 82mm UV/Clear HiDensity filter that will fit the HM700 with the Fuji 17X and allow the hood to be removed without removing the filter. Ideally one that allows a CP filter to be stacked as well.
    Any in put is appreciated.
    D
    Piotr Niemcewicz replied 16 years, 7 months ago 2 Members · 3 Replies
  • Piotr Niemcewicz
    February 20, 2010 at 10:41 pm
    B+W
    99,8% of transparency
  • Doug Calhoun
    February 22, 2010 at 4:37 pm
    Thanks Piotr. The Formatt I was sold is a nice filter but I have fat fingers and struggle to work up inside the hood to attach the CP after removing the UV/Clear which you can’t stack on. Seems dodgy for the work I do nearly all outdoors in all conditions.
    To be sure, the B&W you mention, is it the standard depth or slim? A second filter can be stacked, correct?
  • Piotr Niemcewicz
    February 23, 2010 at 11:51 am
    this filter is more “transparency cap”, nothing change in picture, clean and clear
    a have several cameras, and on jvc i have B+W,
    its not more expensive and very good glass.
