Activity Forums VEGAS Pro Hitfilm 4 with Vegas Pro 13
  • Hitfilm 4 with Vegas Pro 13
    Posted by Ron Whitaker on August 12, 2016 at 11:50 pm
    I have Vegas Pro 13 and just downloaded the Hitfilm 4 Pro demo to test out.
    But when I go into Vegas, right-click on a clip in the timeline, there is no option in the menu (as there should be) to edit in Hitfilm.
    I think it’s a problem with Vegas, isn’t it? Is there a work around to get it to work?
    Marco Baer replied 10 years ago 2 Members · 2 Replies
  • Marco Baer
    August 13, 2016 at 9:55 am
    Yes, there is, but it’s a bit complicated:
    – Install HitFilm Ultimate (2) and activate it (you can use the demo version which is still available).
    – Rename program folder (e.g. “HF2U”)
    – Copy program folder “HF Pro 4” and rename the copy to “HitFilm 2 Ultimate”
    – From the program folder “HF2U” copy (overwrite) the file “HitFilmFileIOPlugin.dll” to the program folder “HitFilm 2 Ultimate”.
    – In program folder “HitFilm 2 Ultimate” (which should be the copy of “HF Pro 4”) rename the .exe file to “HitFilmUltimate.exe”.
    – Be sure in the Vegas Pro program folder the file “HitFilm 2 Ultimate.fio2007-config” exists and it contains the correct path (to “HitFilm 2 Ultimate”).
    Once these modifications are done the workflow of using HitFilm Pro 4 from within Vegas Pro 13 should work the usual way (at least it does for me).
  • Marco Baer
    August 22, 2016 at 6:18 pm
    Did this work for you?
