Activity › Forums › Adobe After Effects › Hit a snag – Boiling Water
  • Hit a snag – Boiling Water
    Posted by Craig Nazimek on July 18, 2008 at 4:06 am
    I’ve hit a major snag with a VFX shot. I’m trying to give the effect of a pond boiling (like if you you were boiling water in a pot). I have a shot that I took with a tripod of the pond in question. I thought I had an idea by using the “Mercury” plug-in but it turns put that I can’t do what I originally intended. Any help would be greatly appreciated.
    David Bogie replied 18 years, 2 months ago 3 Members · 4 Replies
  • Craig Nazimek
    July 18, 2008 at 8:52 pm
    What do you mean by foam, please explain.
  • Craig Nazimek
    July 18, 2008 at 8:53 pm
  • Scott Roberts
    July 21, 2008 at 8:23 am
    You might also try Particle World – with it set to Lens Convex. Andrew Kramer over at Video Copilot made a tutorial called Energy that demonstrates this . . . kind of makes a bubbly effect.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
  • David Bogie
    July 21, 2008 at 4:10 pm
    the next step is often to figure out how to do a reflection map on the distortion. I usually just default to Colorama and use a custom color wheel that uses samples from the main scene.
    bogiesan
