Activity › Forums › Apple Final Cut Pro Legacy › History Channel Transition
Posted by Kevin Jones on October 24, 2006 at 6:25 pmI
Chris Borjis replied 19 years, 10 months ago 7 Members · 8 Replies -
Juan Salvo
October 24, 2006 at 6:33 pmThe saphire plugs have a couple that work for this. But you might be happy with the MUCH cheaper CGM filters, specifically one called Luma Color Dissole.
Kevin Jones
October 24, 2006 at 6:42 pmIs there a stock effect in FCP that come close to this look?
Thanks.
Kevin jones
2.5GHz Quad-core PowerPC G5
4GB DDR533 NON ECC 4X1GB
2X500GB Serial ATA-7200rpm
16x SD DL(DVD-R/CD-RW)
NVIDIA GF 6600 256 SDRAM
Final Cut Studio -
Enge
October 24, 2006 at 6:44 pmTry doing a non-additive dissolve to a white field, that sometimes gets the desired effect.
David Roth weiss
October 24, 2006 at 9:14 pmKevin,
Beware!!! That transition has quickly become the most overused effect on television. Its everywhere now, not just on the History Channel. So, use it at your own peril, as it become kind of a joke in the industry.
DRW
Shane Ross
October 24, 2006 at 10:23 pmI USED to use that transition. On a History Channel show called THE NUCLEAR FOOTBALL. And on a few VH1 shows and a couple Discovery shows. When it was new and COOL! It is a Sapphire plugin, as was mentioned. A Glow transition. But yeah, it has quickly become overused.
Just Joes Filters has one called Chroma Glow…it is a filter, but if you keyframe it it will do the same thing.
Shane
Littlefrog Post
http://www.lfhd.net -
Mark Raudonis
October 24, 2006 at 11:53 pmRight up there with geometric wipes on the old GVG switchers… so seventies!
Mark
Kevin Jones
October 25, 2006 at 3:48 amI guess bad taste never goes out of style!
Thanks for the help!Kevin
Chris Borjis
October 25, 2006 at 4:31 pmYeah everyone and their brother has used the crap out of this transition.
You can do it in after effects by adding the glow effect and key framing the intensity up or down.
