Activity Forums Storage & Archiving Highpoint RocketRaid 4522 with El Capitan
  • Highpoint RocketRaid 4522 with El Capitan
    Posted by Bruce Mccallum on November 14, 2015 at 5:10 pm
    I have been using the HighPoint RR4322 controller card for 3 years until Yosemite was released, at which point it ceased to work. I upgraded to the 4522 card as it was allegedly compatible with Yosemite but it caused FCPX to freeze, the entire computer to freeze requiring a hard shutdown and sometimes the RAID itself to spontaneously to eject. I tried Highpoint support which was frustrating and eventually gave up as I was busy and had to complete projects – I was able to continue with the 4322 card in Mavericks and all was well.
    Now that I have more time and El Cap and newer versions of FCPX have been released I’m trying again, but the card continues to cause the same problems as before. I have updated the card’s firmware to the latest version without a change in behaviour and am back in contact with HighPoint support. Their main solution now is that the old 3Gb/s drives I have in the RAID enclosure are not compatible with the 6Gb/s 4522. I’m not convinced and don’t want to spend money unnecessarily so I’m in a bit of a situation.
    Both the 4322 and the 4522 cards work fine with Mavericks and the 3Gb/s drives, so I’m seriously doubting that the slower drives are causing such extreme problems. I can understand that they may be slower and less efficient, but causing software and system freezes with the occasional spontaneous RAID ejection doesn’t seem drive related to me.
    I may be wrong of course, hence the post – has anybody out there had any experience with the 4522 and El Capitan? Does anyone have a suggestion that might help me out?
    I’m using an early 2009 Mac Pro 2 x 2.26GHz, 20 GB ram, ATI Radeon HD 4870 512MB Graphics
    Thanks…
    David Chai replied 10 years, 3 months ago 3 Members · 2 Replies
  • Bob Zelin
    November 16, 2015 at 9:08 pm
    happy to help –
    how do I contact you ?
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • David Chai
    January 24, 2016 at 6:07 pm
    Had a 2522 that was freezing like you said in Yosemite. Firmware update solved the issue.
    David Chai – Writer . Director
    http://www.davidchai.com
