Activity Forums Maxon Cinema 4D highly reflective badge texture and environment mapping
  • highly reflective badge texture and environment mapping
    Posted by Gareth Wrafter on November 11, 2008 at 1:39 pm
    Hi guys hope you are all well
    I have been experimenting now with reflective surfaces but one thing I can not get my head round is reflections from an environment map I want to render a logo out with a metallic look to it but only render the logo with nothing else around it I have tried an environment with a texture but I can not seem get my head around it could someone point me in the right direction any help would be much appreciated I have attached a file for the look I am after I would like to know how environment maps work is it menu>objects>scene>environment then applying an image to it ??
    many thanks G
    Adam Trachtenberg replied 17 years, 9 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    November 11, 2008 at 4:56 pm
    Environment maps are assigned through materials. You have to go to the material’s Basic tab and check the Environment box. Then go to the Environment tab and assign your map.
    You’ll get the best results with an HDRI, but any bitmap will work.
  • Gareth Wrafter
    November 12, 2008 at 10:02 am
    Thank you very much
    I did find that after posting this although I did wonder if there is a map that is applied to the whole scene rather than individual objects/materials so that different materials reflect the same map?
  • Adam Trachtenberg
    November 12, 2008 at 4:36 pm
    There is no global environment map. What you could do is map your texture to a sky object and then give the sky object a compositing tag with “seen by camera” unchecked. Then use reflectance rather than environment in your materials.
