Activity Forums Adobe Premiere Pro Highlight/Shadow Flicker
  • Highlight/Shadow Flicker
    Posted by Rob Sgarlata on June 16, 2006 at 12:38 pm
    I have applied the highlight/shadow effect to a couple of clips. I am getting some flicker at the end of one of the clips and can’t determine the cause or how to fix it. Can anyone offer some guidance?
    Rob
    Rob Sgarlata replied 20 years, 3 months ago 2 Members · 2 Replies
  • Lloyd Coleman
    June 16, 2006 at 1:39 pm
    Is the ‘Auto Amounts’ box checked? If so, Premiere looks at each frame and does an automatic adjustment. If the lighting/subject changes very much from frame to frame Premiere will change the amount of adjustment needed to correct each frame. This will often look like ‘flicker’ as you see the frames with different adjustment viewed at normal speed. To correct this, when you have the ‘Auto Amounts’ box checked you will also have the ‘Temporal Smoothing’ adjustment available. Put a number in the box and Premier will look at adjacent frames when determining the amount of adjustment for each frame. By looking at adjacent frames it won’t correct one frame too much more than the previous and next frame, thus reducing the ‘flicker’ effect you are seeing. You can also check the ‘Scene Detect’ box so Premiere won’t take into account the exposure of the next scene when averaging the adjustment of the current scene.
    I hope this helps.
  • Rob Sgarlata
    June 16, 2006 at 2:02 pm
    Thansk, that sounds like exactly the fix I need. I’m a little surprised because there is not much movement. It is basically a talking head clip, but it was shot in a living room in the evening, so there may have been rapid changes taking place in the natural light. I will work with these adjustments.
    Thanks again.
