Activity › Forums › DaVinci Resolve › Highlights for Resolve v9
  • Highlights for Resolve v9
    Posted by Peter Chamberlain on April 19, 2012 at 11:33 pm
    For those who missed NAB in Las Vegas. Here are some highlights for Resolve v9.
    Peter
    Interface re-designed to streamline the grading process
    o Fast user login by entering user name or scroll user thumbnails
    o Browse and select projects with scrubbable thumbnail or list view
    o Search and sort project lists
    o Larger color palettes with direct user access to more tools for faster grading
    o Larger and clearer text to ease eye strain during long grading sessions
    o Larger timeline thumbnails makes selecting shots faster
    o Resizable gallery stills stored and displayed in user named albums
    o Gallery now includes 48 ‘Looks’ for fast grade selection
    o Full screen viewer mode for accurate window and qualifier control
    o Cinema review mode offers a clean full screen to sit back and enjoy
    Clip Management
    o Browse and select clips in the media library with thumbnail or list view
    o Re-sizeable and scrubbable Library and Media Pool thumbnails
    o Fast clip management with drag and drop clips between bins in the Media Pool
    o Clip list view now also displays PAR, video/data level, frame rate and audio channels
    o Optional automatic creation of the Master Timeline to match the Media Pool
    o Master and Default timelines option to sort in timecode order or reel # and timecode order
    o Reveal clip in Finder
    Conform
    o Expandable timeline view for conforming
    o Drag and drop clip editing
    o Consolidate RED camera clips with user defined handles
    o Speed warps from FCP XML and Avid AAF
    o User selection of common keyboard shortcut layouts
    Color
    o Log grading includes contrast and pivot with low and high range controls
    o Composite RGBA clips using embedded Alpha
    o Stereoscopic 3D floating windows include position, softness and rotation
    o Separate 3D monitoring controls for GUI/SDI/WFM mesh
    o Camera Raw palette offers real time direct control of raw images
    o Camera Raw image debayer and decode settings optionally saved per graded version
    o Nodes can now be named and wire linking is faster
    o Window palette displays the selected windows and position
    o Key shapes and position are displayed in the new key palette
    o Image transforms are now controlled in the sizing palette
    o Tracker and stabilization palette with editable keyframe tracks for pan, tilt, zoom & rotate
    o Stabilization strength control to blend stable and original image track
    o Eight colored user selected pins & flags to mark clips for fast & easy location and sorting
    o Clip thumbnail timeline filters for color corrected, tracked, rendered, pins and flags
    o User configurable preset descriptions for graded version names
    Audio
    o Multitrack audio decoding from BWF, Quicktime and MXF files – Op-Atom and OP-1a
    o Multitrack audio encoding to Quicktime and MXF formats – Op-Atom
    o Audio waveform display and 16 channel audio meters with selectable dB and dBu scale
    o User selectable reference alignment levels for dBu scale
    o One-click Auto-Sync of multiple dual system audio files with camera images
    Dailies
    o Dailies production metadata fields for fast data entry
    o Automatically assign iXML production metadata with audio sync
    o Dailies clip sort and simultaneous multiple format rendering
    o Simple text name burn in for dailies deliverables
    o Source clip data burn-ins include custom text, logos & user selectable fade up/down times
    o One click generation of LUTs from the clip grade
    o User configurable folders to save LUTs
    Deliverables
    o Dedicated screen for creating rendered deliverables includes large viewer and timeline
    o Deliverables user easy setups can now be saved and recalled
    o Batch render queue shows job status
    o Encoding and decoding Avid DNxHD in QuickTime
    o Avid DNxHD444 codec encode/decode is supported on all platforms
    o Up to 50% faster DNxHD/MXF encoding speed
    o Additional ‘Force Highest Quality’ settings when rendering clips
    o Additional Resolve control panel controls for Camera Raw selection
    General
    o Resolve Control Panel shortcuts to new Log, Raw and Stereoscopic controls
    o Canon C500 camera support
    o Improved decoder performance for uncompressed MXF on Linux
    o Projects are now saved in file based database with optional database server
    o 4K monitoring with DeckLink 4K
    o Resolve for Mac OS; hot plug and play for removable drives
    o Resolve for Mac OS; now a 64 bit app
    Peter Chamberlain replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
