Activity Forums VEGAS Pro Highlighting where media is used on timeline from media pool.
  • Highlighting where media is used on timeline from media pool.
    Posted by Ozvideo on May 15, 2006 at 7:54 am
    You can preview your projects media clips in the media pool but is there any way to click on a clip in the medai pool & have it highlight where the clip is on your timeline. I realize that this might not be possible since the media pool usage count is often wrong & even sometimes reports that every clip has been used twice when they definately haven’t been used. I’m using version 5. 0d.
    Graham Bernard replied 20 years, 3 months ago 5 Members · 5 Replies
  • Leslie Wand
    May 15, 2006 at 9:48 am
    think you’ll find usage 2 means video AND audio…..
    leslie
  • Graham Bernard
    May 15, 2006 at 10:55 am
    View > Edit Details
    You will see all the Active Take Names .
    You can sort by any of the COLUMN headings to bring those times you need to the top.
    There IS a SELECT tick box and this WILL select THAT event on the timeline.
    You can sort the TAKES and just work with them to have these highlighted on the Timeline.
    So not from Project Media but from Edit View. There is masses to use here!!
    Grazie
  • Edward Troxel
    May 15, 2006 at 1:45 pm
    As leslie said, drag a clip to the timeline and you will see the usage count goes to 2. Delete the video OR the audio and it will drop to 1. So… ANY usage counts.
    Edward Troxel
    JETDV Scripts
  • Gary Kleiner
    May 15, 2006 at 2:13 pm
    [Ozvideo] “is there any way to click on a clip in the medai pool & have it highlight where the clip is on your timeline.”
    Right-click in the media pool and choose Select Timeline Events.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Graham Bernard
    May 15, 2006 at 4:39 pm
    Ah! Of course!!! Me bad: Right Click and pick of the option … I was doing the a lot of the “opposite” yesterday.
    G
