Activity Forums VEGAS Pro Highlighting problems in DVDA3
  • Highlighting problems in DVDA3
    Posted by Paul Gregory on December 12, 2007 at 11:56 pm
    I have been trying to create a DVD in DVDA3 but have run into 2 problems. Once I asked that a scene selection menu be created with 8 per page it appeared to work ok in preview mode with just first thumbnail highlighted. As i clicked right each time several thumnails were highlighted. I went back & deleted firstly all of the text & tried again but the problem remained. I restored the text & deleted the thumbnails & did another preview with the same results. I finally started the entire DVD project from scratch but I had the same thing happen once again. Can the problem be in the MPEG2 file itself?
    I went back to Vegas to re open my project & this time got a message that it could not find a clip generated by the Deshaker script. At the time it was rendered the project only had about a dozen clips followed by 6 veg files from completed chapters. It didn’t say where the missing clip was located so in sequence I opened ever other Veg file but the named clip wasn’t to be found.
    I’m confused. Am I dealing with one problem or 2? Is there any options other then rendering out each completed chapter?
    Thanks in advance
    Paul Gregory replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
