Activity Forums Apple Final Cut Pro Legacy Highest Rez iShowU captures for web movie
  • Highest Rez iShowU captures for web movie
    Posted by David Mayer on February 28, 2010 at 3:39 pm
    I’m creating a web movie using SD footage and iShowU HD screen captures. I want to capture the entire screen and then, in Final Cut, zoom in on certain parts of the screen. Which iShowU setting will give me the highest possible resolution?
    My Final Cut sequence settings are:
    frame size: 720 x 480
    Aspect Ratio: NTSC DV (3:2)
    Anamorphic
    Compressor: DV/DVCPRO – NTSC
    When I try to duplicate these settings in iShowU HD, the .mov files are still not nearly hi-rez enough for zooming in.
    Dave
    Final Cut 7.0
    iMac 2.8 GHz
    OS 10.6.2
    David Mayer replied 16 years, 6 months ago 3 Members · 5 Replies
  • Walter Biscardi
    February 28, 2010 at 4:55 pm
    [david mayer] “When I try to duplicate these settings in iShowU HD, the .mov files are still not nearly hi-rez enough for zooming in.”
    That’s because when you zoom in, you’re blowing the image up so it falls apart.
    What you want to do is start with a larger image in iShowU and scale that down in FCP.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • David Mayer
    February 28, 2010 at 9:22 pm
    Thanks, Walter. Yes, that seems to be the ticket. BTW, why are these files so enormous?
    iMac 2.8 GHz Intel Core i7, 8 GB
    OS 10.6.2
    Final Cut Pro 7.0
  • Walter Biscardi
    February 28, 2010 at 10:19 pm
    [david mayer] “Thanks, Walter. Yes, that seems to be the ticket. BTW, why are these files so enormous?”
    That is wholly depending on the codec you capture to.
    Blog!
    Twitter!
  • Nicole Haddock
    March 1, 2010 at 6:58 pm
    Try capturing ProRes (not HQ) and the entire screen. You can zoom upwards of 3-400% without any major visual loss.
    Also, set your sequence settings in FCP to ProRes as well. DV-NTSC is just going to make these look craptastic.
  • David Mayer
    March 1, 2010 at 8:46 pm
    Thanks Nicole,
    I did try it using Pro Res and it is way better.
    DM
    OS 10.6.2
    Final Cut Pro 7.0
