Activity › Forums › Apple Final Cut Pro Legacy › Highest Quality Export w/ mpeg-4 container & H.264 Codec FCPX
  • Highest Quality Export w/ mpeg-4 container & H.264 Codec FCPX
    Posted by Josh Birch on November 13, 2014 at 2:51 pm
    Hi Guys,
    What is the highest possible export option with an mpeg-4 container (.mp4) with a H.264 codec. My client is asking for this format but can’t figure it out? Know it seem’s a basic question but just wanting the highest quality export
    When I go to Export > Master File it only gives me an option for .mov container with H.264 codec….
    Thanks in advance
    Josh
    John Rofrano replied 11 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    November 17, 2014 at 2:25 am
    [Josh Birch] “When I go to Export > Master File it only gives me an option for .mov container with H.264 codec….”
    You can use File | Share | Apple Devices 1080p then go to the Settings tab and change Video Codec to H.264 Better Quality and render with that. This will produce a file with an extension of .m4v which you can safely rename to .mp4 if that’s what your customer wants. Both simply indicate that are MPEG4 files.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Josh Birch
    November 18, 2014 at 9:24 am
    Should have mentioned that the footage was shot in 720p. Do you just do the same with Apple Devices 720p and then change the codec?
    Josh
    Josh
    http://www.josh-birch.co.uk
  • John Rofrano
    November 18, 2014 at 3:53 pm
    Yes, use Apple Devices 720p.
    ~jr
