Activity › Forums › Apple Final Cut Pro › Highest Quality Export w/ mpeg-4 container & H.264 Codec FCPX
  • Highest Quality Export w/ mpeg-4 container & H.264 Codec FCPX
    Posted by Josh Birch on November 13, 2014 at 3:07 pm
    Hi Guys,
    What is the highest possible export option with an mpeg-4 container (.mp4) with a H.264 codec. My client is asking for this format but can’t figure it out?
    When I go to Export > Master File it only gives me an option for .mov container with H.264 codec….
    Thanks in advance
    Josh
    http://www.josh-birch.co.uk
    Patrice Freymond replied 11 years, 10 months ago 3 Members · 2 Replies
  • Paul Figgiani
    November 13, 2014 at 4:51 pm
    [Josh Birch] “Hi Guys,
    Thanks in advance
    Josh”
    You need to set this up in Compressor. One option is to built a Setting’s Preset using QTExport Components – Encoder Type:MPEG-4 … and then customize by pressing the “Configure” option.
    -paul.
  • Patrice Freymond
    November 13, 2014 at 7:49 pm
    I don’t have fcpx in front of m but if I make no mistake you can create an mp4 file using the “Apple device” setting. One of the submenus will give you the possibility to chose “Computer” and this creates a non .mov h264 file.
    Could be a solution to your problem without goint to Compressor ?
    Patrice Freymond
    Editor  Certified Trainer FCPX 10.1.3
    Post Consultant
    Always learning…
