Activity Forums Apple Final Cut Pro Legacy highest quality compression for You Tube
  • highest quality compression for You Tube
    Posted by David Mayer on July 23, 2010 at 12:25 am
    I’m trying to make the highest possible quality You Tube movie. I’m currently using the “Large Web Movie” setting in Compressor and wondering if there is a higher quality way to do it – maybe something directly from FCP instead of Compressor? I’m working with widescreen SD video in FCP.
    iMac 2.8 GHz Intel Core i7, 8 GB
    OS 10.6.2
    Final Cut Pro 7.0
    Anthony Faulkner replied 16 years, 1 month ago 2 Members · 1 Reply
  • Anthony Faulkner
    July 26, 2010 at 2:36 am
    H.264 is the codec you should use, and assign your frame size from there.
