Activity Forums Apple Final Cut Pro Legacy Highest quality 16:9 output
  • Highest quality 16:9 output
    Posted by Lucas Young on May 20, 2008 at 8:39 pm
    Hi Guys
    I have about 11000 1024*576 TIF files and a 48KHz wav file I’d like to combine and output for DVD, MiniDV and AppleTV. (They came from from an Avid). I want the highest possible quality output which I can then transcode to the various other formats I need. What’s the best preset/sequence settings to do this? I guess not PAL DV Anamorphic?
    I also need a 4:3 version (letterboxed). Would the best way to do this while retaining quality be to use the sequence from above and drop it into a 4:3 sequence and let FCP do the letterboxing? Or is there a better way?
    Many thanks in advance 🙂
    Lucas
    Russell Lasson replied 18 years, 4 months ago 3 Members · 5 Replies
  • Dylan Reeve
    May 20, 2008 at 8:57 pm
    Avid is working with those natively at 720×576 (PAL Anamorphic) – by exporting as Square Pix they have undergone an aspect conversion which is perhaps not ideal.
    If you can still get the Avid stuff it would be better to export a QT Animation file at 720×576 (with the correct display ratio selected) – this will avoid any unnecessary rescaling on export from Avid and use in FCP.
  • Lucas Young
    May 20, 2008 at 9:02 pm
    Thanks Dylan. The footage came from an XDCam and was edited in Avid in 16:9 and then just exported as a sequence of TIF files… so I think the quality is OK there, I just want to find the best format to use when I assemble them in FCP as DV PAL Anamorphic looks horrible
  • Russell Lasson
    May 20, 2008 at 9:21 pm
    I’d suggest using ProRes.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Lucas Young
    May 20, 2008 at 9:53 pm
    Thanks… do you mean Apple ProRes 422 HQ PAL as the sequence preset, with PAL CCIR-601 Anamorphic 16:9 selected in the Sequence Settings option? (We’re in NZ so I’m using PAL). Would I choose Anamorphic 16:9 if the TIF files are 16:9 anyway?
    What about the 4:3 letterboxing… any recommendations?
    cheers
  • Russell Lasson
    May 21, 2008 at 5:40 pm
    I would create a ProRes HQ sequence that is 1024×576 and has square pixels. From there, I would export it using compressor for DVD.
    For your 4×3 version, I would suggest either using compressor to letterbox it or just putting the 16×9 sequence in a 4×3 sequence in FCP or Motion to letterbox it.
    -Russ
    Russell Lasson
    Provo, UT
