Activity › Forums › Adobe After Effects › high-usage inscription in advertisements, how to make?
  • high-usage inscription in advertisements, how to make?
    Posted by Mariia Dakir on February 27, 2013 at 4:34 pm
    Hello everybody,
    very often in ads videos I face with effective inscription-description like in video below:
    https://www.youtube.com/watch?v=WsGBzYB3si8
    starts at 5-6 seconds
    could anybody recommend me plugin or way how can I make it in AE? Any plugin or preset?
    Please help! It is impossible to just googling answer for this question that is why I am asking for your help.
    Vishesh Arora replied 13 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • John Cuevas
    February 27, 2013 at 5:03 pm
    Couple of techniques are used to create that effect. Graphically it’s not hard, one of the type-presets + a stroke to create the line + Glow.
    The other thing is using the 3D camera tracker. Here’s a pretty good tutorial showing how to use the 3D tracker:
    3D Camera Tracker Basics – After Effects CS6
    If you want to pay for a subscription this one looks like it would explain what you want to do also: D Object Tracking in After Effects CS6 – Tuts+ Premium
    After Effects CS6 3D Camera Tracker
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Mariia Dakir
    February 27, 2013 at 5:16 pm
    yes actually I am interesting about creating this text and line and which preset I have to use..
    Although I’ve recognized 3D camera tracking here, thanks for links!
  • John Cuevas
    February 28, 2013 at 2:02 am
    I made an example project and you can take a look at that.
    For the line, I just created a solid(“Stroke”) and used the pen tool to make a straight line and added the Generate > Stroke effect and keyframed the “end”.
    To make the ball at the end of the line, I created a black solid, changed it’s transfer mode to “Add” and added the Generate > Lens Flare effect. I copied the mask path from “Stroke” and pasted that data on to the Flare Center. I then matched up the keyframes so that it would move with the stroke. Lastly I animated the Flare brightness.
    For the text, I had to do this with 2 layers. For the first layer, I just did all the text except for the “]”. I used the preset Animate In > Fade Up Characters. Then I made a text layer of just the “]” and keyframed the opacity and position so it looked like it was racing ahead of the text that was fading up.
    To match your example, I would precompose everything. Camera track the video, create a null point and parent my text precomp to that null.
    Here’s my example project, hope it gives you a good starting point: 5545_stroke.aep.zip
    Thinkck.com
  • Vishesh Arora
    February 28, 2013 at 10:46 am
    Mariia
    John has already given you an excellent way to achieve this effect. Though you may find these links useful:
    Beam Effect with Tracker
    https://vimeo.com/14264152
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Mariia Dakir
    February 28, 2013 at 6:06 pm
    John, many thanks for provided project file and excellent explanation! It is really helpful for me and at the same time I have learned some techniques from this project.
    Hope other people will enjoy this tutorial too.
    Thanks for your time!
  • John Cuevas
    February 28, 2013 at 7:08 pm
    As you can see by Vishesh example in AE, there are a lot of different ways to approach any problem. I’m glad we were able to help you out, if you have any more questions, I’m always happy to help out if I can.
    Thinkck.com
  • Mariia Dakir
    March 1, 2013 at 3:48 pm
    Yes, thanks to Vishesh I also have learned Beam Effect and sure I’ll use it!
  • Vishesh Arora
    March 1, 2013 at 4:31 pm
    Glad we could help Mariia.
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
