Activity › Forums › Adobe Premiere Pro › high speed filter causes field problems
  • high speed filter causes field problems
    Posted by Xabier Giménez on March 26, 2008 at 10:42 am
    hi!
    I am editing some HDV PAL material, 1080i in Premiere Pro CS3.
    When I add a speed effect, with the basic speed tool (not time remapping), usually a 800% or 600% effect (very high speed) some clips play jerky.
    I activate the frame blending checkbox. The strangest thing is that some clips play awesome and some others (taken by the same camera, and played at the same 800% speed) play jerky, as having the fields order inverted. (Only where the speed effect is applied.)
    Of course, i´ve tried the reverse field dominance option, as wel as the deinterlace or flicker removal, with no luck.
    Any ideas?
    Thanks in advance,
    Xabier
    Xabier Giménez replied 18 years, 6 months ago 3 Members · 4 Replies
  • Eric Jurgenson
    March 26, 2008 at 1:20 pm
    It could be the disk (high speed requires higher disk performance) or the CPU (decoding the HDV long GOP frame structure at high speeds). I would try forcing a render, or exporting the original clip to a non-long GOP format and speeding that up.
  • Xabier Giménez
    March 26, 2008 at 2:27 pm
    Thanks for your answer, Eric.
    Unfortunately, the problem appears in the rendered clips. Also exporting to DV, to DVD, etc.
    Xabier
  • Jon Barrie
    March 26, 2008 at 11:35 pm
    Could you post the clip somewhere so we can see the jerky look?
    If you are just speed/duration alting upto 800, have you tried to use the timeremapping to do it? That should look much better.
    – Jon 🙂
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Xabier Giménez
    March 27, 2008 at 2:01 pm
    Thanks for your answer, Jon.
    The jerky look appears only on a TV monitor, not in computer screen.
    Even if I upload the clip you wont see the jerky effect.
    I´ll try Time remapping instead of regular speed up. Thanks for the tip. I´ll report the results.
    Xabier
