Activity Forums Adobe After Effects High Resolution Satellite Images?
  • Thomas Leong
    July 26, 2011 at 1:09 pm
  • Eric Kirk
    July 26, 2011 at 7:53 pm
    I’ve asked similar questions before but bottom line is if you go to a satellite company specializing in this, they will charge you and arm and a leg.
    One option that I looked at is to use google earth. If you poke through the settings once you find your location, you can remove the little icons, street names, and all that junk leaving you with a pretty clean image.
    From there, a screen shot or something.
    Hope that helps.
    Eric
    Eric D. Kirk
    http://www.kirkproductions.com
