Activity Forums Avid Media Composer High Res Jpeg
  • High Res Jpeg
    Posted by Dan Newton on May 16, 2009 at 12:26 pm
    Hey guys
    have a quick question — I have been given a high res jpeg — 720 x 576 — now they want me to just place this jpeg in the avid and let it play for 3 seconds — they want to send it off for broadcast — now if they give me the high res jpeg and i put it into the avid — the picture is going to look quite bad — so what do you suggest — should I put it through photoshop first or what — please help me out on this —
    and do I need to reformat the picture
    Please Advise
    James Beattie replied 17 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Michael Phillips
    May 16, 2009 at 4:01 pm
    have you tried it and it looks bad, or are you guessing that it is going to look bad?
    Michael
    Michael Phillips
  • Dan Newton
    May 16, 2009 at 4:08 pm
    Hey
    It looks a bit pixelated — even though its a very high res jpeg
    any suggestions
  • Grinner Hester
    May 16, 2009 at 5:33 pm
    meaning… resize it first in photoshop. Don’t let Avid do it.
  • Grinner Hester
    May 16, 2009 at 5:45 pm
    Resize it to 720X486 and bring it in uncompressed without resizing it.
  • Dan Newton
    May 16, 2009 at 6:06 pm
    Hey
    Thanks for the feedback
    So as we work on Pal here — i can bring it in as 720 x 576 — make sure its RGB — and ignore the alpha channel
    it should be ok —
    Please Advise
  • Grinner Hester
    May 16, 2009 at 8:22 pm
    yes, just let avid resize it when you import it. Check your import settings.
  • Kris Anderson
    May 17, 2009 at 6:34 am
    If it’s already 720×576 then Avid shouldn’t be resizing it at all, it’s native PAL. What resolution are you importing at?
  • James Beattie
    May 20, 2009 at 12:35 am
    There is an effect called pan and zoom. Apply this to a clip in your timeline. Go into the effect editor and click on the minus sign in the upper left corner. Choose your hi res graphic, and it will allow you bring it in higher res, and do moves on it. This is the best Avid only way of doing it.
    There is a plugin from stagetools.com that does it better, but costs.
    I believe there is also a BCC effect that does it as well.
