Activity Forums Adobe After Effects High res comp questions……..
  • High res comp questions……..
    Posted by Jim Fergades on January 5, 2014 at 2:53 am
    Hello,
    I’m new to the forum and would like to say thank you in advance for any help You can give me.
    Is it possible to make a comp with a resolution of 19200×1080 to span across ten screens?
    Each screen has the same HD resolution of 1920×1080 and I want to combine ten 7 minute videos to cover all screens at the same time. Can I do this in AE, and would it be easier on the PC to run this large resolution video or just run the ten 1920×1080 videos output separately to the ten monitors? I would use Resolume Arena to play the ten different small videos if I can’t merge them in AE or if I will not gain anything by doing so.
    Thanks again!!!!!!!
    Jim Fergades replied 12 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Walter Soyka
    January 5, 2014 at 11:34 am
    [Jim Fergades] “Is it possible to make a comp with a resolution of 19200×1080 to span across ten screens?”
    Yes. An After Effects comp can be up to 30,000 x 30,000 pixels.
    [Jim Fergades] “Can I do this in AE, and would it be easier on the PC to run this large resolution video or just run the ten 1920×1080 videos output separately to the ten monitors? I would use Resolume Arena to play the ten different small videos if I can’t merge them in AE or if I will not gain anything by doing so.”
    This really depends on the performance of the playback system. A lot of playback systems built for multiple screens are actually networks of players and prefer pre-splitting content for the displays to lower playback requirements.
    You have to work backwards here; you’ve got the displays figured out (ten 1920×1080 displays), next you need to figure out the playback system, then finally you deliver your media according to its needs.
    If you haven’t done this sort of thing before, testing is critical.
    Walter Soyka
  • Jim Fergades
    January 5, 2014 at 4:40 pm
    That’s actually where I’m at in the project right now.
    I’ve been looking at the system I want to build for this and am not sure what would be the best way to go.
    I’ve been looking at multiple pcs networked vs. one GPU intensive pc.
    Not a ton of info either way but the one pc seems to be the most economical and best for this install.
    Didn’t want to post questions about the system as I didn’t think this was the correct place to do so.
    Thanks…
  • Walter Soyka
    January 5, 2014 at 6:12 pm
    [Jim Fergades] “I’ve been looking at multiple pcs networked vs. one GPU intensive pc. Not a ton of info either way but the one pc seems to be the most economical and best for this install. Didn’t want to post questions about the system as I didn’t think this was the correct place to do so.”
    I don’t think you should expect 10-channel HD playback from a single PC, unless you reduce the resolution a ton and do some kind of scaling after output. I do a lot of multi-display work, and I generally max out at 4 outputs per PC with Dataton WATCHOUT clusters.
    Walter Soyka
  • Jim Fergades
    January 5, 2014 at 6:30 pm
    Thanks for the info.
    I can scale back on the resolution if necessary as I’m only using 32″ monitors…
  • Walter Soyka
    January 5, 2014 at 7:23 pm
    [Walter Soyka] “I don’t think you should expect 10-channel HD playback from a single PC, unless you reduce the resolution a ton and do some kind of scaling after output.”
    [Jim Fergades] “I can scale back on the resolution if necessary as I’m only using 32″ monitors…”
    I was referring to a massive reduction in resolution and number of outputs, with some kind of multi-destination switcher to handle scaling and distribution. Even 10 outputs of 1280×720 is a lot to expect from a single machine.
    Maybe it’s feasible with DXV (if DXV can go that large), but I would certainly want to test that extensively before committing to it. Multiple synced servers with fewer outputs each would probably be more reliable.
    Walter Soyka
  • Ericbowen
    January 6, 2014 at 6:13 pm
    The problem you run into here is less to do with hardware processing capability currently and more to do with the limitations of the software player processing that type of frame data when spanned to over 8K resolutions. The latency of that kind of pixel data processing is just to high often for realtime which is why you require nodes with separate player hosts to handle that which is what Walter is talking about. Essentially 8K is normally where the single system with 1 player host break point is though some can push to 12K.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • Jim Fergades
    January 7, 2014 at 8:30 pm
    Thanks for all the info. I’m going into test mode for awhile to see how different setups work. I have 5 pc’s to work with and access to pretty much whatever hardware I need before I build the final machine or machines. Will update when fished.
    Thanks again…..
