Activity Forums Adobe After Effects High res clouds
  • High res clouds
    Posted by Peter on June 24, 2005 at 11:03 am
    I am working on an Animation in AE pro 6.5.
    I have a very large bkgd image..8000/400.
    Two things. I want to render it as it is so that I can pan and zoom.
    Depending on ones system is there restrictions on size in AE in rendering ?
    If anyone has worked with very high res images I would be grateful for any tips or tuts.. if there are any on the subject.
    Also I would like to create some clouds for the sky.. Possibly with particel playground if there is any advice on doing that also I would welcome it.
    Thanks in advance for any assistance
    Trug
    Peter replied 21 years, 2 months ago 5 Members · 5 Replies
  • Steve Stone
    June 24, 2005 at 2:04 pm
    I am not aware of an actual limit, however I have worked with projects with very odd aspect ratios i.e. 14790 X 48, and it still seems to handle it fine. As you mentioned it prob. depends on your system. I have however, had issues with output of large comps and I found that it really depends on the codec that you use. Uncompressed quicktime usually works, but a tga sequence is most likely your best bet. I hope this helps. Good Luck!
    Steve Stone
    S t e v e S t o n e
    A n i m a t o r
    D X D ( P o s t / D e s i g n / F X )
    https://www.d-x-d.com
  • Chris Borjis
    June 24, 2005 at 4:30 pm
    I believe your limitations will be related to your
    system/cpu/memory specs.
    I remember working on some rather large pans
    and zooms on my old system years ago and having
    out of memory errors. I had to resize down
    the pictures, then it worked and still looked
    great.
    The sizes that were huge and didn’t work
    ended up being overkill anyway.
  • Lriv
    June 24, 2005 at 4:34 pm
    to create your clouds check out example 46 of this tutorial website:
    https://www.ayatoweb.com/ae_tips_e.html
  • David Johnson
    June 25, 2005 at 2:11 pm
    If plugins are within your budget Aurora Sky available from Digital Element and Digital Anarchy, as well as The Foundry’s Sky plugin (part of Tinderbox 1) both make very nice clouds.
  • Peter
    June 27, 2005 at 6:49 am
    Cheers. I do have access to at least one of those plug ins.
    I will have a bash
    Trug
