Activity Forums Blackmagic Design High Quality YUV Rendering Problem
  • High Quality YUV Rendering Problem
    Posted by Roddy Jamieson on September 4, 2005 at 3:18 pm
    I recently finished an edit in FCP5/Decklink Extreme @ 8 bit, and decided to re-render at the High YUV setting as I had several ‘resized’ 4:3 shots to 16:9. The results on these parts was excellent, much more resolution. But my titles and some photoshop keyed captions displayed red blue and green cubes around what appeared to the ‘alpha’ chanel, not on the graphic itself but around it. Any Ideas?
    Roddy Jamieson
    Kristian Lam replied 20 years, 11 months ago 3 Members · 5 Replies
  • Steve Drew
    September 5, 2005 at 8:28 am
    Thank god someone else is having this problem!
    I’ve been too busy to post it recently and have just been rendering everything at 8bit as everything WORKS at 8bit. 10bit also gives awful results on multiply transfer modes in the timeline.
    I get the green garbage around my photoshop alpha edges, as you said, but only when I’ve got a drop shadow on it. I’ve found a cumbersome way around it:
    Firstly, check that the clips giving you the grief are photoshop “sequences”, not the individual layer from the photoshop sequence.
    Then remove any FCP drop shadow effect.
    Open up the photoshop sequence by double clicking it
    Apply the drop shadow to the layer INSIDE the sequence
    Than return to your master sequence – all should be good.
    It would be dandy if this was sorted.
  • Steve Drew
  • Roddy Jamieson
    September 5, 2005 at 9:20 am
    Thanks for that, it only shows on Photoshop captions when I applied, in this case a ‘cube spin’ effect, it shows as the image compresses. I had a lower third name caption over an after effects animated background with drop shadow and it gave the garbage with no effect applied.
    I don’t know if this is a Blackmagic or FCP problem, I guess the boys at BMD are busy with IBC. I’ll wait and see if they can shed some more light on the subject.
    Roddy Jamieson
  • Kristian Lam
    September 6, 2005 at 2:25 am
    Hi Roddy,
    I’m having trouble reproducing this problem. Perhaps you can send us an email at support[at]blackmagic-design.com or if you have any test files, drop us a download link so that we have a common working reference.
    regards
    Kristian
    Blackmagic Design
  • Kristian Lam
    September 28, 2005 at 12:58 am
    Hi guys,
    We’ve replicated this problem and further testing points the problem to a possible bug in FCP. We have logged the bug appropriately with Apple and are waiting for their response.
    regards
    Kristian
    Blackmagic Design
