Activity Forums Apple Final Cut Pro Legacy high quality render advice from book
  • high quality render advice from book
    Posted by David Hunter on August 17, 2008 at 8:42 am
    The working codec on my project is DVCPRO 720p50 HD which was from footage shot on the Panasonic HVX201A. The widescreen television in a reception area in Munich, Germany is presumably PAL.
    For the final DVD output I want the highest render possible even though I do not have multiple processors, just the 2.4ghz iMac intel core 2 Duo and 4GB 667MHz DDR2 SDRAM. The external hard drive media and scratch drive is rated at 7200 or 7400 rpm with a Firewire 800 connection.
    Lonzell Watson’s book “Final Cut Pro 6 For Digital Video Editors Only” says: “If you require a higher-quality render than what the DV codec provides, you can always change your Final Cut Pro sequence settings to Uncompressed 10-bit and then export your movie. You may want to also consider exporting via the Animation codec”.
    Are both of these solutions applicable to my computer in terms of data-rate flow? Should the rendering process during editing START with one of these codecs and stay with it all the way through to the final project once I have established the desired aspect ratio and frame rate when I ingested the footage from the P2 cards using the DVCPRO HD 720p50?
    Do the uncompressed 10-bit and animation codecs provide the best solution to creating the master before taking it to DVD Studio?
    Thanks for your experience!
    David Hunter replied 18 years, 1 month ago 2 Members · 2 Replies
  • David Roth weiss
    August 17, 2008 at 9:06 am
    [David Hunter] “Lonzell Watson’s book “Final Cut Pro 6 For Digital Video Editors Only” says: “If you require a higher-quality render than what the DV codec provides, you can always change your Final Cut Pro sequence settings to Uncompressed 10-bit and then export your movie. You may want to also consider exporting via the Animation codec”.”
    David,
    He’s talking about the DV codec, not DVCProHD. DV has a color space that terribly degrades graphics when rendering. DVCProHD doesn’t do that.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • David Hunter
    August 17, 2008 at 9:20 am
    Ahhh…thanks David.
    I was taking “DV” to be a generic reference to the multiplicity of DV encodings formats….
    Appreciate that…
