Activity Forums Adobe After Effects high quality output
  • high quality output
    Posted by Xavier Khonje on November 7, 2007 at 3:53 pm
    Hi guys am duffy
    am kinda a bit new to ae but am working on an advert. Tell me I want to create one good ad for tv but when ever I import files from flash they just dont look appetising the look as if I rendered them in 3gp but not really
    how can I transfer files without them losing quality and suitable for tv broadcast?
    and how can I sustain this good quality when am done at ae for compiling?
    cheers duffy
    Richard Harrington replied 18 years, 10 months ago 3 Members · 2 Replies
  • Michael Duff
    November 7, 2007 at 11:03 pm
    hi duffy … i haven’t used flash for a while, but from what I remember I think there is an “export movie” option under the file menu … then you need to choose a file type .. go with quicktime Animation. import this file into AE, do your compiling and then render out using the render queue … again choose quicktime with the Animation codec …
    make sure you output from flash at tv resolution .. ie 1024×576 for PAL 16×9
    does this help you?
  • Richard Harrington
    November 8, 2007 at 2:12 am
    Use AE CS3
    Imports Flash as vector.
    be sure to click continuously rasterize
    Workflow throughly covered in Help menu
