Activity Forums DVD Authoring High Quality DVD Slideshows
  • High Quality DVD Slideshows
    Posted by Thomas Hanser on November 14, 2016 at 8:52 pm
    So…if DVD only supports 720×480, how can I render and burn a DVD slideshow if my timeline is 1920×1080?
    Most TV’s are much higher resolution than 720×480, obviously. And my first test burn looked terrible scaled up on a flat panel TV. Obviously that won’t work.
    I created the slideshow using very high-res Photoshop files in a 1920×1080 timeline sequence. But this is scaled way down in Roxio Toast, resulting in a useless presentation for large TV’s.
    (I’m a little out of practice in terms of authoring DVD’s – all my work goes on the web these days.)
    Thomas Hanser
    Seattle, WA
    Thomas Hanser replied 9 years, 10 months ago 2 Members · 2 Replies
  • Jeff Pulera
    November 15, 2016 at 4:05 pm
    DVD is a specification, and that spec is for standard-definition video only (720×480). If you want HD video on a disc, then you would make a Blu-ray disc instead.
    Perhaps a better option – export an HD file using H.264, resulting in an .mp4 file. Save to a USB thumb drive stick. Plug USB stick directly into TV. Play HD video. Some Blu-ray and DVD players also now have USB ports, same thing, plug and play with stick.
    Jeff Pulera
    Safe Harbor Computers
  • Thomas Hanser
    November 15, 2016 at 8:40 pm
    Thanks, Jeff.
    Playing an .mp4 file from a thumbdrive sounds like the only answer! ?
    Thanks again.
    Thomas Hanser
    Seattle, WA
