Activity Forums Panasonic Cameras high-quality 4:2:2,
  • high-quality 4:2:2,
    Posted by Martin on September 4, 2005 at 2:01 pm
    Can the AG-HVX200 P2 cam record in high-quality 4:2:2, 50Mbps DVCPRO50
    Toke replied 21 years ago 7 Members · 13 Replies
  • 13 Replies
  • Häakon
    September 4, 2005 at 5:39 pm
    Yes.
  • Donatello
    September 4, 2005 at 6:34 pm
    the spec’s call for DVCpro50 4:2:2 .. it remains to be seen how high quality the images will be as nobody has seen any images from the ccd’s ..
    kind of like the dvx100 is 4:1:1.. is it high quality ? compared to say the sdx900 in dvcpro25 mode ?? they are both 4:1:1 .. the 2 images do have a different quality … depending on your preference one might consider the images from the 2/3″ CCD camera higher quality then the 1/3″ CCD camera ??
  • Noah Kadner
    September 4, 2005 at 8:16 pm
    That’s the HD lenses, CCDs and better internal processing on the SDX900 too. One hopes you get those for the added $$$.
    Noah
  • Martin
    September 5, 2005 at 8:56 am
    Can the cam record both NTSC and pall or just the one
  • Brian FitzGerald
    September 5, 2005 at 3:14 pm
    I would assume the 4:2:2, 50Mbps DVCPRO50 signal has to be recorded to the P2 card(s) but I don’t know that for a fact. Can anyone confirm or can your record it to the DV tape?
    Brian FitzGerald
    FitzVideo.com
  • Noah Kadner
    September 5, 2005 at 4:18 pm
  • Noah Kadner
    September 5, 2005 at 4:54 pm
    The tape deck is for standard DV only. DVCPRO50 goes to P2.
    Noah
  • Brian FitzGerald
    September 6, 2005 at 1:03 am
    Thanks for the reply, Noah.
    Brian FitzGerald
    FitzVideo.com
  • Martin
    September 6, 2005 at 9:44 am
    Thanks for that. One final thing If I shoot in pal and then interpret footage to NTSC, will the quality be the same as if I shot the footage in NTSC
    By the way how do you lay the link for the brochure, how do you do that?
    Martin
  • Martin
    September 6, 2005 at 12:15 pm
    Then the camera is not cheap, How can they say charge so much money for a memory chip, this will obviously deter a lot of people in buying the cam. Panasonic will no doubt in a year or two lower the price but only after most of their cutomers have bought some other wonderful invetion, Sony, ect…Who is going to buy a cam for 6 grand only to shoot SD…..If you buy the memory and end up spending 10 grand then it ust be very very gooooood!
