Activity Forums Apple Final Cut Pro Legacy High Precision YUV Render Faulty
  • High Precision YUV Render Faulty
    Posted by Tobin Nageotte on July 12, 2005 at 11:06 pm
    I’m working with anamorphic 720×480 clips in FCP 4.5. I’m able to transfer my clips from a 720×480 sequence into a 4:3 sequence (my final out) and they letterbox correctly. However, when I try to render the 4:3 sequence at “high-precision YUV” (SequenceSettings>VideoProcessing) the clips become a Matrix-like mess in the Canvas window. I’m able to render the 4:3 sequence at 8-bit YUV, but some still pics that I animated in After Effects look blurry and flicker (which they don’t when I render the 720×480 sequence with “high-precision”).
    I’ve read my manual and Ken Stone’s article on Render settings, I believe everything is set properly. If this is an issue b/c of the shift in aspect ratio, does anyone have a suggestion for making my AE clips look less blurry at an 8-bit YUV render?
    Thanks.
    – Tobin
    Tobin Nageotte replied 21 years, 2 months ago 2 Members · 2 Replies
  • Walter Biscardi
    July 13, 2005 at 10:57 am
    If you’re working with DV footage, there’s no reason to use the High Precision YUV settings. 8bit is a correct setting for DV footage.
    High Precision is only needed if you’re working with 10bit native SD or HD footage.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Tobin Nageotte
    July 13, 2005 at 9:27 pm
    Thanks.
