Activity › Forums › AJA Video Systems › high pitch audio buzz
  • high pitch audio buzz
    Posted by Frank Cann on January 12, 2011 at 2:28 pm
    Just recently I started experiencing a high pitch audio hum/buzz (for lack of a better word) during analog acquire (Media 100). After several tests I found that it’s not coming from any deck (either that or its coming from every machine – highly unlikely) and it only goes away when I disconnect the AJA breakout cable (duh). In fact, it even goes away if I only disconnect the green (y) video connection – but then I don’t get anything – it must be an “all or nothing” situation. Could it be the breakout cable?
    Bob Zelin replied 15 years, 8 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    January 13, 2011 at 3:03 am
    Sounds like a ground problem. What is on the other end ? A patch bay of some sort?
  • Bob Zelin
    January 15, 2011 at 6:15 pm
    Hi Frank –
    I have seen AJA cards cause interference with the internal MAC Audio. So how are you monitoring your audio – are you listening to the output of your Kona card (which should be perfect), or are you monitoring the output of your MAC computer ? Exactly, what are your speakers listening to?
    Bob Zelin
